When I am loading gint and get a popup that says something like “the master library has been updated, do you want to update it now” (see attached) , if I click "yes" , it replaces the library that I am using with some standard templates. Is there a way to update the library without loosing all my previous(created) templates? Is there a way to stop receiving this popup too ?
How to do it with setup.gsh?
Or I ask all the users to go to their system properties and manually remove the master library path ?
Yes, ask the user to remove it manually.
It is only in an event when gINT crashes with a specific error message related to the master library. In that event, you have to do a setup.gsh.
