I would like to enter the AASHTO system in my GINT. Gint by default includes USCS system.
Refer to the file attached.
To my knowledge I will need to create another lookup defining each material with the AASHTO system. Can anyone elaborate?
Thanks.PDF
If you're going to be working in AASHTO for many project and not just a few one-offs, then I would recommend changing the name of your "USCS" field to "Classification" (or similar) and then just adding the AASHTO classifications to your current lookup list for that field. You'll need to do the same for your "Graphic" field.
Thanks Allan,
I plan to use AASHTO very few times, so will not be frequently. I was wondering if there is a way to create an AASHTO template and use it when needed.
Yes. There are different ways to go about it. If you want to keep your USCS and AASHTO projects VERY separate then you should copy your existing Data Template and Library, rename accordingly, and then edit them individually.
The other option is to edit your current Data Template and Library to be more robust so that it can handle any number classification systems.
