I have a soil data table that contains odor information with depth, among other descriptors. Values include "no", "chemical", "organic", etc. For some reason, the values for odor only are not being printed into the report in output, even if the cells are have data. What could be causing this?
Thanks in advance
You'll need to post a screen capture of the Field Properties from the Data Table as well as the Text vs Depth Entity from the Report Design so we can see what's up.
