When I import additional UNC data for Unconfined Compression Testing for a single boring, any previously entered or imported UC data in that same boring is deleted.
For example, I had previously imported and entered data for boring B-1 @8 and B-1 @12. When the remaining 2 unconfined compression tests were completed, I imported the data for the 2 addiitonal files only. When I went to enter the manually entered data, the data for the 1st 2 tests was gone! This only happens when importing data for the same boring number. When I imported data for borings B-2 and B-3, no data was deleted for B-1.
We have offices that do large quantities of UC testing and need to be able to import and complete tests on a daily basis. What can we do to correct data being deleted when additional data for the same boring is imported?
Judy Smith
If the Add-In menu module you are using was generated for you by Bentley, you should contact Bentley Technical Support for assistance. (This does not include the freely-downloadable gINT Rules examples you find in the WIKI here.)
If it was generated by a third party, you should contact the creator for assistance.
