Hi all,
Is there any ideas why the DICT table is not exported in the AGS file?
The table is set in the database (with data as it should) and the gcx file looks ok. It's an AGS4 file export.
Thanks.
Dave,
That's exactly what I did, probably something else that I miss is wrong!
Dennis,
It is also possible that there is a bug in gINT causing the problem. I will add a non-standard field to a table and then update my DICT table. From other postings it looks like you are running the latest posted gINT build. I am not running the latest build, so I am not sure it that will help out much but it is worth a try.
That might be the case. I'm not running the latest built of gINT (I'm using 8.30.02.39). Hopefully I'm going to have it installed today and give it a try again. Thanks, Dave.
Sorry about that. Your posting about the AGS Checker is what I was thinking about. Kathleen suggested installing 8.30.03.077, I thought you were already running that. My mistake. My build is older than what you are currently running.
gINT latest built installed (8.30.03.077), DICT table updated, correspondence file updated and checked DICT table still nowhere in the AGS4 exported file. It seems like I'm missing something or something is wrong.
any ideas?
