Multiple graphs in one report
Hello there,
Im looking for a way in gINT to present multiple graphs in one report (a4). I noticed there is a way for multiple frames per sheet where it allows you to print more than one graph, but only under the condition as long as the independent data axis is the same.
I cant find anywhere the possibility of creating more graphs with different independant data axis (in this case the X-axis) in the same report. Does anyway know how to achieve this?
Thanks in advance!
Sake Boele,
The Netherlands
  • This capability is now native in gINT v8i, at least at the Professional Plus license level. It is in the current release version, v8i SS1. The description in Help says only, “This property allows you to select one or multiple reports to overlay onto the master report to create multi-graph reports.” The topic in the current Help file that covers this in depth is “Multi-Graph_Reports”.
    It is a Property of a Graph report, in the General tab, to select Overlaid Reports. The Overlaid Reports need to be of the same report application (Graphs), and they must be designed to be overlaid.
    That being said, since the overlaid report/s are defined separately, they can have different independent data axes.
  • Hey Pat! Is the overlay capability available on gINT Professional? If not, is it planned to be? We are running gINT Professional, and I do not see an option for Overlaid Reports in my General Tab for my graph reports.
  • Judy, like Dave said, it is available for both gINT Professional and gINT Professional Plus. I am using v8i version 8.30.03.135 (the current release version), and I see the Overlaid Report property in the Graph Report Properties General tab for both levels.
  • Thanks, Pat! I found out what the problem was. IT hadn't updated our software in a while and the version they had me running was too old to use the report! Once I got it updated, everything works great.
    Hope to see you at the Bentley conference this year!
Reply Children
