gINT V8i Print Error "Failed to set up Paper Sourse, setting previous printer"
Hi all,
I'm getting this message when I try to print: "Failed to set up Paper Sourse, setting previous printer".
I'm using Win7 64bit and I was resently updated to gINT built 08.30.03.77. This error occurs as soon as you select print (output tab) regardless of the default printer. Note that I only have network printers.
Any ideas?
Parents Reply Children
