Sake, the actual report may have been done as a customized report for a contracted project, or as a proof of concept for the new Multi-Graph feature.
If the latter, it will likely be uploaded to the Geotechnical WIKI as an example in the near future.
Sake, the example was done as a proof-of-concept piece, so I was able to upload it to the WIKI here.
Check out the Multi-Graph Example dataset. Play with it, and if you have any problems printing the multi-graph report, please contact Technical Support.
Hello Pat,
Thank you for your reply! The Multi-Graph Example dataset (zip) contains however no data. Could you upload the data again?
With regards,
Sake
Sake, I downloaded the ZIP file and extracted from it a folder (MultigraphDataSet) which contains both a gINT library, multigraph_library_skinny.glb, and a gINT project file , multigraph_project_skinny.gpj.
The project file contains information about a single borehole with Triaxial Shear data. The library contains (among other necessary resources), two graph reports, TRIAXIAL MAIN and TRIAXIAL OVERLAID, which are needed to produce the single final multi-graph report output.
I don't know how you download the zip, but up here the zip file contains still no data at all??
