Gradation Spec Limits on Grain Size Distribution Graphs
Using the new feature for adding gradation specification envelopes, is it possible to show more than one envelope on a graph? I'm currently using a report variable to show one envelope.  If I add another report variable for a second envelope neither shows.
Thanks.
  • Using Graph Properties | Data Representation | Curves from equations, you can display many envelopes.  I think this data should be stored in the project database, since from my experience envelopes vary project by project.
    This is an example grabbing data from a project file, forming a list of vertices, and defining data marker, data marker height, and data marker colour
    <<IndDepList>>_
    <<SqlList(";",_
      SELECT [LAB_SPECIFICATION_PSD].[Particle_Size] & "," & _
      [SPECIFICATION_PSD].[Percent_Passing] _
      FROM [SPECIFICATION_PSD] _
      WHERE [SPECIFICATION_PSD].[ItemKey] = '<<POINT.Fill_Type_1>>' _
      AND [SPECIFICATION_PSD].[Sign] in ('<=','<') _
      ORDER BY cdbl([LAB_SPECIFICATION_PSD].[Particle_Size])_
    )>>_
    <<Let(DMKName = <<User System Data.DG Lab Fill Type 1 Dmk Name>>)>>_
    <<Let(DMKHt = 2)>>_
    <<Let(DMKColor = <<User System Data.DG Lab Fill Type 1 Colour>>)>>
    Phil Wade
    Datgel
    Bentley Channel Partner and Developer Partner
    E: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
    Get the most out of gINT with Datgel Tools.
Reply
    <<IndDepList>>_
    <<SqlList(";",_
    )>>_
    <<Let(DMKHt = 2)>>_
    Phil Wade
    Datgel
