Can't Find Sample Table
Trying to create a new table for input of Sample data, but having trouble creating new table.  In the process of creating a new table I get the error message Sample table already exist but I can't seem to find it anywhere?
  • J, you should check in INPUT under the Table menu, the List option. The SAMPLE table probably exists, but is hidden. In the List dialog, you can turn off the Hide checkbox and it will appear.
    If not, try going into DATA DESIGN/Project Database, opening the Current Project, and checking the drop-down list of tables in the project. If you don't see SAMPLE, add a new table in DATA DESIGN. If you get the same error, you should contact Technical Support.
Reply
  • No Luck with either of those Pat; nothing in the input/list and when added SAMPLE in DATA DESIGN, I can add it but it does not show up in my tale list or under the INTUP tab?
    P.S.  Are you the same Pat that was friends with Brandon Burden and Chris Emanuel.... I think we used to know each other,  I lived with those guys for a few years back at CSM, went by Brian then though
