Below is the list I have created. I would like to add commas between each parameter.
The list is written like this because this is the order in which the parameters need to occur. However, I can't simply add the comma's into the IIf functions since not all parameters are analysed in every sample. Eg sample is analysed for BTEX, F1-F4, Pb or PAH only.
<<ListBuildSepTrim(_
<<cr>>,_
<<IIf(<<TESTS.BTEX>>, BTEX,)>>_
<<IIf(<<TESTS.BTEXH>>, BTEXH,)>>_
<<IIf(<<TESTS.VOC>>, VOC,)>>_
<<IIf(<<TESTS.CVOC>>, CVOC,)>>_
<<IIf(<<TESTS.12-DCA EDB MTBE>>, "1,2-DCA, EDB, MTBE",)>>_
<<IIf(<<TESTS.Selected VOC>>, Selected VOC,)>>_
<<IIf(<<TESTS.F1-F4>>, F1-F4,)>>_
<<IIf(<<TESTS.PAH>>, PAH,)>>_
<<IIf(<<TESTS.2 & 3 Ring PAH>>, 2 & 3 Ring PAH,)>>_
<<IIf(<<TESTS.SVOC>>, SVOC,)>>_
<<IIf(<<TESTS.Selected PAH>>, Selected PAH,)>>_
<<IIf(<<TESTS.Metals>>, Metals,)>>_
<<IIf(<<TESTS.Pb>>, Pb,)>>_
<<IIf(<<TESTS.6 Metals>>, 6 Metals,)>>_
<<IIf(<<TESTS.Selected Metals>>, Selected Metals,)>>_
<<IIf(<<TESTS.PCB>>, PCB,)>>_
<<IIf(<<TESTS.Pesticides>>, Pesticides,)>>_
<<IIf(<<TESTS.Grain Size>>, Grain Size,)>>_
<<HasData(<<TESTS.Additional Parameters>>,<<TESTS.Additional Parameters>>,)>>_
Any suggestions?
D., the ListBuildSepTrim() function already has this capability - instead of the separator being <<cr>> to add a line feed, it sounds like you want a comma to be expressed at the end of each test line (followed by a line feed). So you make that part of your separator expression:
<<ListBuildSepTrim(_ ","<<cr>>,_ <<IIf(<<TESTS.BTEX>>, BTEX,)>>_ <<IIf(<<TESTS.BTEXH>>, BTEXH,)>>_...
The embedded comma needs to be in quotes, as otherwise gINT will assume it is the first comma in the function.
This will work to place a comma plus a line feed as a separator between each list item that returns data and the next.
See the gINT Help topics Functions Overview and ListBuildSepTrim (function).
