Hello
I’m trying to plot my design lines from a large number of boreholes. I’d like to use graphs, not logs, as I have a large number of boreholes to show on one graph.
I’d like to plot the design values of certain geotechnical parameters vs depth. The table I’m reading from has the structure: top, bottom, phi. I’d like to draw a line between two points with the following x:y coordinates:
I can’t make this work in gINT graphs. Has anyone faced a similar problem and found an answer?
Hi PeeKee
You can follow the same approach I suggested here:
communities.bentley.com/.../78457.aspx
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
Jerome
