Is there a way in Fence drawings to force the legend to have a colour fill according to its Geol Code.
For example, if it was a Made Ground and I set a Geol Code of MG for that material, how would I get it to backfill red in the column on the fence?
There must be an expression for this but I can't figure it.
Mr_Adam, the simplest way to do this is to set the symbol background color for the MG symbol to Red in the SYMBOL DESIGN application Material tab, by adding a SOLID in the first column (Fill Type![Symbol]), and setting the Override Color column to Very Light Red for that row.
This will result in the MG symbol always being red, even on other Fence and Log reports.
