.I have exported the data into AGS format, however, when I try to use the AGS Checker (by gINT), it doesn’t recognise that it’s in AGS4, but it assumes that the file is in AGS3 ; even if I select the AGS4 custom dictionary in the Checker.
The checker says:
Checking PROJ Group 1 error or warning or informational message
ERROR: No PROJ_AGS field found in the PROJ group. Unknown AGS version. Version 3 is assumed.
However, when I see the PROJ table requirements for AGS4, there’s no such option as PROJ_AGS
Do you have any idea what could be the problem?
Many thanks!
enter a value in the heading TRAN_AGS, say 4 or 4.0.3
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
