On a number of occasions I have wanted to write a gint rule to perform calculations using data in a table and use the results to populate a field in another table. I have not been able to figure out how to write to another table that is not the direct parent of the table that triggered the rule.
Thus far I have been handling this situation by writing a script file that outputs the required results to a temporary file and then imports the temporary file into the correct table. Yes I can convert the script to a gint rule but the table events do not allow the running of scripts from gintrules code. Thus I have to manually trigger the rule using the add-in manager each time it needs to run. This is OK but I would like for it to run automatically on exit from the particular input table. The genral flow of the rule I would like to write for a table named "CurrentTable" with output to a table named "TargetTable" would be:
Clear all data from TargetTable
Read grid data from CurrentTable
Begin loop of the records in griddata
Perform calculations with fields in CurrentTable record
Add record to TargetTable and write results to that record
Perform more calculations with fields in CurrentTable record
Add another record to TargetTable and write results to that record
Loop to next record in griddata.
END
Thus for each record in CurrentTable I might end up with several records in TargetTable. TargetTable would be completely recreated each time the rule is run. Again, TargetTable is not necessarily the parent of CurentTable so I cannot use:
With gINTRules.GridData.ParentRecord .Edit .Fields("FieldOne") = lNumber .UpdateEnd With
Seems like a simple thing to do and I have written VBA code in excel to do the same thing but just can't figure out how to do it in gINT. Any guidance anyone can give me would be appreciated. Thanks
In short, you need to do one of the following:
1. Use update or insert SQL statements to write data to the second table
2. Make a record set, which involves an sql select statement, of the second table. Loop thru the record set editing data etc
Read up on DAO, which is the data access library in use.
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
