Hi
Just wondering if anyone has worked (or is working) to integrate the Lab Testing Module with the AGS4 template.
Cheers
Tom
Hi Tom
Datgel has a number of classification, compaction, chemical, rock and aggregate test calculations and reports developed in gINT, this is in our Datgel Lab and In Situ Tool product. It uses the same database as our DGD gINT Files v2 product, hence it supports AGS4 and AGS 3.1. At this time it is designed for BS and ASTM, we will be expanding this to NZ and AS.
You can see some of the reports here: www.datgel.com/.../DOT2_All_Reports.pdf
I'll be at the NZGS Symposium in November - i could give you a demo then , or we can do a web demo almost any time.
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
Hello Tom,
We are in the process of adding the lab tables to, updating the reports, etc in our gINT Std AGS4 files. We'll post them on line when they're ready and update this post.
Hi Kathleen
Thanks for the reply - do you have any idea of timeframe for this work?
Phil - thanks for that - we'll catch up in November.
My guess is that it will be at least a couple of months.
