Report Design - Log clean-up
I have gINT Professional v08.30.03.135
I am attempting to clean-up the look of our logs and I can't figure out how to make the depth column join nicely with the lithology column for small layers of stratigraphy (see print screen attached).
I only have this issue for small intervals. I only way I've been able to fit it is to decrease the depth per page (ie stretch that section out).
Is there a way to smooth out this transition?
Let me know if you need more data.
Document1.pdf
