Overlaid graphs, range filter
When generating a graph which includes an overlaid graph, the range filter is not passed on to the second graph by default.
Anybody have any experience in passing on the range filter?
Thanks in advance
Martin
  • Hello Martin,
    I tried the range filter and it works for me.  We'd like to see your files. I'll send you an email so we can arrange this.
    If you need your user report variables to prompt the user for something that does not yet work.  Partly because we are unsure how it should work.  For example, if your main graph is overlaid with say 5 graphs, each with it's own set of URVs, should a separate dialog open for each one?  That would be annoying for the user.  How do you see this working?  We'd appreciate some input on this.
Reply
  • Hello Martin,
