Missing data scales on logs
I'm trying to put data scales on logs displaying different soil parameters with depth, however the data scales are not appearing.
This happens when I use mutiple plot vs depth columns for plotting one paramter type vs depth from multiple test sources (e.g. undrained shear strength from triaxial tests and from shear vanes). However for some boreholes data is only availble from one source, which I think may be part of the reason for the data scales not appearing.
I also have plot vs depth columns for design lines which will always be present and try to input the data scale information in these column boxes but this still does not solve the problem.
Parents Reply Children
