Multi page Fences
Morning all,
Is it possible to spilt a fence between two (or more) pages?
For example, when you have many exploratory holes along a long cable route?
Many thanks for your ideas.
Dai
  • Hello Dai,
    That's a good question.  Yes, you can split up the fence into multiple pages.  Here are some suggestions:
    One way is to select which boreholes you want to output.  If you have many this is not practical.
    Draw a custom baseline near the boreholes you wish to output.
    Use the Minimum and Maximum Distance Axis fields.  The Maximum for the first page becomes the Minimum for the second.  This is probably the simplest option.
    Click the Site Layout button on Output.  Draw a zone around the area you wish to output.
    Import alignment data and use this to filter on.
    I'll contact you privately to send you documentation that will explain these different options.
    Answer Verified By: David Donaghy
  • Kathleen,
    Many thanks for your answer, much appreciated. After posting the question we experimented with these options and they seem to do the trick. I will download the documentation also and try it out.
Reply Children
