gINT 8.2 and Excel 2007 - SHBT Tables
I recall that there was an issue between gINT and Excel 2007, which would always results in an error when it came down to the SHBT Tables.
gINT did release an update to solve this issue, but i keep getting "
ERROR 381
Invalid property array index
Anyone know of another solution for this issue.
Parents Reply
  • In case anyone else runs into this issue, it was fixed by installing a newer build of gINT.  Aly described the problem this way:
    "This is an INPUT problem, under the LAB tab, Shear Box. No matter which sample you choose in the top, the sample number does not change. In addition sometimes the input data is saved and on many other occasions it does not, that too, you can only add information pertaining to the first sample in the table, as you are unable to move between the samples. This is not a  standalone problem for a particular project, it is the same for all project."
    I don't think Excel 2007 was related to the problem.
    Answer Verified By: Ali Abdelaziz Ali
  • The problem has been solved by installing this the version provided (upgrading the version does not solve it). gINT should be uninstalled and re-installed again. We tried it on all the PCs that run gINT in the office, and it works.
    Thank you Kathleen for the support. (Y)
    Aly Abdelaziz Aly
    Technical Manager / gINT Manager
    Al Hai & Al Mukaddam for Geotechnical Works LLC
    P. O. Box 60462 | Dubai | U.A.E. | Office Tel: +971 (4) 8854854 | Office Fax: +971 (4) 8854853 | Lab Tel: +971 (4) 8854771 | Lab Fax: +971 (4) 8854772 | Mobile: +971 (50) 6450510 | Email: ali@ahamgeo.com
