<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>gINT-MASTER LIBRARY FILE</title><link>https://communities.bentley.com/products/geotechnical1/f/geotechnical-forum/98274/gint-master-library-file</link><description>Hello,
 I am new to gINT V8i Professional and Geopak V8i SS2.
 Regarding specifying the library file in the system properties; I see in the help that the Master Library is managed by administration but the library file above it is required. If I leave</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: gINT-MASTER LIBRARY FILE</title><link>https://communities.bentley.com/thread/288833?ContentTypeID=1</link><pubDate>Mon, 23 Jun 2014 14:00:28 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:e9e41581-a3bf-4e01-94cf-f98caf68ab1a</guid><dc:creator>Aparna M</dc:creator><description>&lt;p&gt;Hello,&lt;/p&gt;
&lt;p&gt;If you leave the Master Library file blank, it will not cause any problems. &amp;nbsp;But if you happen to have a central library file that is required for all the users using gINT. then you might want to keep the master library path for that central library,&lt;/p&gt;
&lt;p&gt;As its mentioned in the help, the Master Library is commonly administered by a gINT Manager and each time when the master library gets updated on a central location (this location could be a central network location or ProjectWise), &amp;nbsp;gINT users will be prompted to update their local library.&lt;/p&gt;
&lt;p&gt;The Library file (listed above the Master Library) specifies which library file to use. &lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
