Where can I find documentation for the Keyneix API
Good morning David
Please go to: https://www.bentley.com/en/software-developers/bdn-inquiry-form
Many thanks
Mel
I submitted a request via the link above 5 days ago and have not received a reply.Is there documentation? If so, who might know where to obtain it?
Hi David
Your application has to go through a process, once it's been reviewed a member of the team will be in contact. Apologies, but I can't give you a time frame for this
Kind regards
I already have the SDK and am working on a project for Langan Engineering with people at Bentley (Mundeep Verdee, Philip Child, James Slater). I'm just looking for documentation. Why do I have to be "reviewed"? Are you able to at least indicate whether or not documentation actually exists for the SDK? This is specifically:Bentley.OpenGround.SDK.1.1.50.58Is there someone else or somewhere else I should be looking? The work being done is on a timeline...- da
Hi David,
I understand that you've had a response offline to this query. As indicated there reference material for the API/SDK is being developed. In the meantime your existing contacts will be better placed to advise on any specific questions you have in this area.
Kind regards,
Phil
