With Holebase (local installation) the columns in a grid had a line separating each column so you can see which column the data belongs in.
But OpenGround Professional has removed that line so now, number data can be easily mistaken for belonging in the adjacent column.
Any chance of putting that line back? Or aligning the number data under the text?
Hi Mark,
I will ask the team about this again but don't think it will be possible as OpenGround theming is now Bentley theming which has no vertical line. I will check though and update this post later.
Martyn
Ahh okay....
Can the numbers be aligned to the left then so its under the title of the column?
That would make sense if you cannot put the line back. Or give the database/config pack or project the control of the alignment?
This has been driving me crazy too! An option to turn on vertical column border would be great.
Values on the right side of the column typically indicate the data type is a number, while left aligned entries are text strings. This distinction is important, but there other ways to show it (fonts, italics, etc).
