When inputting all information into the Dynamic Probe Sampling or Dynamic Cone Penetrometer data entry no matter what data is inserted Keynetix will not create a log. The blows will not show on the produced log.
Hi Sonny,
I think this is a problem with the Template itself. Below are links to version which I have fixed. To import the files go to System>Configuration Packs>Select the pack>import components. Then import each file.
https://bentley.sharefile.com/d-s70c8b76a9074b6cb
https://bentley.sharefile.com/d-s0158c8a8ab34d2a8
Martyn
Hi Martyn,
I am having the same problem as Sonny mentions, and I tried opening those links and it said the link does not exist. Is there any chance you could repost those Templates? Thank you
Conor
