Has anybody managed to succesfully deploy Holebase using the network based installation here?
https://communities.bentley.com/products/geotechnical1/w/wiki/50263/holebase---Essentially
The instructions not working....
My situation is Holebase has already been manually installed on a device with the license server configured which the client connect into fine.
We are looking to create additional deployments which can be deployed via SCCM to several devices.
Here is whats been done:
Extracted the Pre-Requsites from "HoleBASE_SI_Installer.exe" and created a script to install these. Once this has been installed, installs "Keynetix.HoleBASESI.WIXx64.msi" also extracted. Whenever Holebase application is launched , license error occurs, attempt to connect to the existing license manager by selecting network license , enter the host name and save. Error returned advising that "Could not find local license server, please ensure "Sentinel Local License Manager' service is installed. The correct host nameis being entered.
If full installation is run using "HoleBASE_SI_Installer.exe" it installs pre-reqs and Holebase, application is launched and allows for the network license host name to be saved without any issue.
Trouble is there is nothing extracted in relation to "Local license server" So the question is if all pre-reqs are successfully installed and you run the "Keynetix.HoleBASESI.WIXx64.msi" how are you supposed to install the license server which installed when run by "HoleBASE_SI_Installer.exe"?
I have attempted copying the HoleBASESI.config file from the machine that has already been configured, but this made no difference.
Also the "HoleBASE_SI_Installer.exe"? does not support silent command line paramaters so this cannot be used for SCCM deployment.
Any thoughts on how this situation can be resolved without manually installing on these target devices?
Hi Martin,
I think the licence driver that would normally be installed with the .exe would need to be installed Manually. You can download the driver from this link:
https://bentley.sharefile.com/d-s74c69738cb244fdb
Maybe you can add that to your silent install.
Just to confirm, did you copy the config file to: C:\ProgramData\Bentley\HoleBASE If so it should work.
Thanks Martyn
