I'm having trouble with getting standpipes to display on logs.
I have followed the steps here:
Well/Installation not showing on log after entering Pipe Work data - OpenGround | gINT | Keynetix Wiki - OpenGround | gINT | Keynetix - Bentley Communities
That is, a standpipe is selected in the Monitoring Instruments table, and pipe references are consistent.with the monitoring pipe work table.Still only the backfill details are shown on the default percussive log template.
What can I do to fix this?
Hi James
It might be that the borders for the pipe are not set correctly. Are you using the default Percussion Drilling Template?
Yes, this is using the default British Standard template.
Please can you send the data for that project in AGS4 format, to: mel.towler@bentley.com
For anyone else who reads this, I have managed to fix it - it's a template issue.
1) In Holebase Template Studio, take a look at the template concerned then cells in the "Well" column.
2) Make sure that the top cell concerns backfill and the cell beneath is for installation (this apparently is important).
3) Also make sure that the properties for installation include a border thickness of 0.5.
4) Save the template to the configuration pack, or in some other way to ensure you can use it with your project.
Thanks James, yes perfectly correct and thanks for jumping in
