Hi
Could anyone explain what this AGS import error is "5508 5508:0 to 5508:0 Error Header data type is inconsistent with other entries." Line 5508 is the TYPE line and has the same data types as ASG 4.0.3
"GROUP","LBST""HEADING","LOCA_ID","SAMP_TOP","SAMP_REF","SAMP_TYPE","SAMP_ID","LBSG_REF","LBST_TEST","CHOC_REF","LBST_TTYP","LBST_METH","LBST_PREP","LBST_DEPN","LBST_STAT","LBST_REM","LBST_DUE","LBST_DETL","LBST_DONE","FILE_FSET""UNIT","","m","","","","","","","","","","","","","yyyy-mm-dd","","yyyy-mm-dd","""TYPE","ID","2DP","X","PA","ID","X","X","X","X","X","X","X","PA","X","DT","X","DT","X"
regards
Phil Wade
Hi Phil
We were investigating this yesterday, but couldn't find the cause. We will continue to investigate and will keep you updated
