Hello, I am having an error precluding the succesful import of the whole batch.
Error says: Identical key fields '[UNIT_UNIT:pH Units]' (Line 47, Position 47:0 to 47:0)
please advice how to fix file
thanks in advance
Alfonso
Hi Alfonzo,
I think you will have 2 units in the UNIT table that are the same for pH. Review the table and see if there is a duplicate to remove.
Martyn
Thanks! This helped me.
I am having a similar issue with Holebase. I am trying to import a .ags file that I received from a client but i am getting an error stating that there is a duplicate sample ID.
I tried opening the file in excel to find the duplicates and then save it as a .csv file but Holebase then gives me a warning saying the unrecognised table will not be imported.
Is there any way around this?
Noel
