Hi. I am having a problem with importing an AGS file into HoleBase. The error message that I get reads "no parent field in table 'LOCA':[LOCA_ID:BH210]". This repeats for all the exploratory holes in the project. When I checked the LOCA able, all the boreholes appear to be present and correct. Can you help me with correcting the issue?
I found my own answer, so no need for further replies. In case anyone else has a similar problem - The LOCA table had been corrupted. At a few locations, the data line, instead of being a single continuous line of data for each location, had been split into three consecutive lines. When i used NotePad to remove the offending line breaks so that each location had a single line of data, the errors disappeared.
Hi Steve
Many thanks for confirming and thank you for the explanation
The following Al’s Supermarket Survey Guide will help you to check your eligibility, rules, and official links to win Al’s Supermarket Rewards.
