I am trying to import Atterberg limit and Moisture content. Do I have to follow specific format as Location Details.csv file. Also, How can I add Liquid Index tab in Hole Base.
Hi Tanvir,
It would be a similar format. You can export the Limit and Moisture grids from HoleBASE as CSV and use those as templates. You would also need the sample information CSV.
Martyn
