I want to set up an expression that uses PI.
Can this be done using an equivalent to PI() in excel or do I just have to use a numeric value?
This is for setting up a calculated field within the Holebase model.
Hi Tim,
You would need to use the numeric value set to the precision you need.
Martyn
