Hi there,
Is there a way in template studio to display depth related remarks at their depth? (similar to the image below) The current template we have set up doesn't include them and I have yet to find a solution to being able to display these types of comments within a strata.
The current work around (below) we have is to include it in the main description, but it gets clunky and harder to read. It would be nice to see listed next to (or near) the depth they were noted at.
Thank you!
Hi Jenae
You might be able to do this in Template Studio. Do you have this please?
Hi Melanie,
Yes - we have Template Studio.
J
Hello Melanie,
Is there any update on if there is a solution available in Template Studio to make these depth specific remarks?
Thank you,
Jenae
Hi Jenae,
Did you ever get this sorted?
thanks
Scott
The Stratum Detail Descriptions table in OpenGround is intended for entering and storing comments like this within a strata.
The Description Bar object then has properties you can adjust to get the Stratum Detail Description comments to appear as you'd like within the main Description column.
Alternatively, the screen shot in the original post above appears to show the comments in a separate column, which could be done by creating a separate column/strip in Template Studio and using, for example, a Point Data Text object to display the comments.
