https://communities.bentley.com/products/geotechnical1/w/wiki/50417/keyags-free-version
Clicking on the 32 and 64 bit links in above page just redirects to gINT|Keynetix wiki page without starting a Download.
Win10/Android
Chrome/chrome for Android/MS Edge
Hi Mel,
The links keep causing my laptop to crash and won't install. Do you have an older version? Do they require a specific operating system?
If you could drop me a message that would be great.
thanks,
Misbha
Hi Misbha
Slightly older builds can be downloaded from the link below
32 bit https://bentley.sharefile.com/d-s5df793968ff24e228b19fac7eb7b2f65
64 bit bentley.sharefile.com/d-s42c3ccce8dc940aeb24112ddc5bc9c0c
I've tried to download these again and it still causing my system to collapse. I've tried two different computers and both the 32 bit and 64 bit versions. Is it that the files are corrupted? Do you have a solution to this? I'm assuming AGS isnt required to have the keyAGS software downloaded?
thanks
Please follow the steps below and download the latest hasp drivers from the link
After downloading the file, extract and save the "haspdinst.exe" somewhere you can find it.Go to start and in the run box type "cmd", locate the cmd.exe in the list, right click it and select "run as administrator"Once the command window opens type "cd" followed by a space and then the path through to the folder where the "haspdinst.exe" is saved, for example:-cd C:\Users\**your account***\Desktop\haspdinstand then press "enter"next type: Haspdinst.exe -purgeThe old driver will then be removed. Once it has been removed go back to the command window and type in:-Haspdinst.exe -iThe driver will then be installed meaning KeyAGS can be installed when running the installer.
bentley.sharefile.com/d-s5105c2716e2843708112f2aad553a525
Great thanks! Its been downloaded and working now!
