Holebase SI CONNECT - Create Configuration Failed
I'm setting up a new holebase database for one of our business units. To do this I've exported our existing Configuration Pack (*.hbp) then tried to import it into the new database. This runs for about 30 - 40mins then crashes and the config fails to import.
I have had success with importing a default configuration (Australia Default) so it must be an issue with the custom config pack we're using.
Can I please get some help resolving this issue? As I need this config imported to maintain our data profiles and templates.
Jayden Gesche
