Hi all,
Looking to recreate sections from saved section lines in HoleBASE SI v1.34.3.68.
Have saved the section line, but cant create sections as the "Create Section" Button is greyed out. Anybody know a way to reactivate the line so I don't have to keep drawing new section lines. Cheers.
Hi Tom, You need to change the mouse type to "Select" mode from the ribbon. You can then select the line on the map.
Answer Verified By: Tom Bonsall
