Holebase accepts non-numeric data (eg >140) into the [InSituVane.Result] field.
Using the expression;
if(len([InSituVane.Result])>0,'HVP=' + text(fixed([InSituVane.Result], 0, false)),'') + if(len([InSituVane.Result])>0 and len([InSituVane.Residualresult])>0,', ','') + if(len([InSituVane.Residualresult])>0,'HVR=' + text(fixed([InSituVane.Residualresult], 0, false)),'')+'kPa'
will only output numeric data.
Non-numeric data isn't output.
Am I using the wrong data test "len > 0" in this expression?
Hi Tim, Looking at it, i dont think you need the len parts. Just the if greater than zero should do it I think.
