Afternoon All,
A client has sent over an AGS file that appears to have been exported from gINT. Our company only has access to HBSI. It is coming up as an AGS4 file, however when trying to import, I can only proceed when selecting it as a gINT file. When we hit next, to import, HBSI comes up with an error and causes the programme to crash everytime!
I have included some screenshots. I've never come across having to upload files that have been exported from gINT before. Is this something that can be easily done as project time is limited.
Thanks!
Hi Hannah
Could you please upload the file to the link below and I will investigate the issue
bentley.sharefile.com/r-r78cb868cd4d947a6926ecc6b859038f1
Thanks Melanie, I have done
Please download the file from the below link and let me know if this resolves the issue
bentley.sharefile.com/d-s93bec200f0ba4d0b878c9e0852a21473
Hi Melanie, that has worked! Thank you! Please can I ask what you changed to allow it to go in?
Sure, in the TRAN table, the AGS version was 4.0.4, I changed this to just 4.0, which fixes the issue
