Hi
I am a one-man Consultant and I think my PC, which is very slow at the moment, has updated itself over the last couple of days and now I am trying to sort some logs out, I can't log into Holebase.
The message I get states 'Failure to connect to database: Could not find database server.' Please help as I have no idea what I am doing.
Many thanks,
Kevin Bullock
Hi Kevin, if this is still an issue you may need to log an SR. However, please have IT check that the SQL service is running on the server and that your PC can connect to it.
Martyn
