I am working on a project where we are using a drilling rig which has the capability to carry out windowless sample, rotary cored and rotary open hole drilling. I am trying to summarise the information on the same log template, where the relevant data sets are all displayed; SPT, RQD, TCR etc. When I print the log, I get two seperate logs, a WLS BH and Rotary Core log with bits of information on each but it doesn't look very good.
Hope that makes sense
Hi Sam
You can create a Log Report. Please see the link below on how to do this. You can also create a new Template to show these details, but unsure if you have Template Studio to design your own logs
communities.bentley.com/.../how-to-produce-a-log-report
Your project sounds interesting! It seems like you're trying to streamline your drilling data and create a more cohesive log template. I can definitely see how having separate logs for windowless sample and rotary core drilling could be cumbersome. On a related note, I recently worked on a workover rig repair where we had to replace some of the drilling equipment. It was quite the undertaking, but in the end, it helped optimize our drilling operations. Good luck with your project!
