Good Morning,
When plotting a Standard template Rotary Core Log, the sample information such as the sample reference and depths are occupying the same depth on the log as the Fracture index/coring information - is there a way to separate or offset?
Thanks in advance
Hi Colin, You can try using Grouping from Dept Columns options in TS, however it may not work due to the coring information boxes. You may be better off having a separate column for sample information and reference.
Martyn
