Installed AGS v. 444_83 on a windows 10 laptop with office 365 intalled. But the add in does not show in Excel. I have managed to install it on some computers but not all.
I have removed the reg files and uninstalled the application via add/remove programs, but when i reinstall and add the license reg file it still does not apple.
Nothing showing in Disabled addin either.
Hi Sean, for the install are you using the setup.exe or the MSI? The setup.exe will install the item needed for the menu to load. If you use the setup.exe and the menu fails to load still please log an SR for this issue.
For the licence, you need to run Excel as an Administrator an then go to KeyAGS4>Help>Licence and then apply the file.
