Keylab - Conditional formatting not showing up on output reports
I designed an output sheet with conditional formatting to fill a cell with color based on its value.  When I test the formatting on the sheet it works as it should.  However, when I batch print reports the conditional formatting does not show up.  I was wondering if there was somthing I was missing as far as how keylab functions with conditional formatting and output reports. When I am batching the reports I click off the "Remove Colour" option from the box that pops up with print options. I have also left it checked.  No difference.
How my sheet is setup:
On the input sheet I have it reference values for a particular specificaion.  Using index match I have it reference a table to pull in values based on the test.  The values are labeled as such:
Property  Top Specification  Bottom Specification
1/2                       5                          -5
3/8                       4                          -4
etc....
Each top secification and bottom specification has its own propery.  So in the example there would be 4 properties associated with it.   12in_top_spec     12in_bottom_spec
This would continue through the table.
On the output report I import the values into a second sheet.  So the output report has 2 sheets.  The main output report and the table sheet.
I then put the proper reference cells into this table sheet.
It would look somthing like this. This is from an actual batch report:
So using these values
I goto a cell in the report.  Click on the conditional formatting for the cell and would type:  =OR(E18>'Values for Spec'!C4,E18<'Values for Spec'!B4)  With value for spec being the sheet pictured about.
I should note.  That if I don't reference a sheet in conditional formating and just -4 instead of "valuesforspecc4" the conditional formatting works.  The problem with this is I have 2 sheets that have different specs depending on the test so I can't do that.
Thanks in advance for any input.
