When importing AGS data into Holebase, not all of the data is importing, even though it is being displayed in the AGS file. For example, I have records for a borehole and all the information except the geological description and detailed description are being imported. I have had this issue before with various categories of data, all seemingly for no reason. Until now, I have manually added this information directly into Holebase. Can anyone advise as to why this may be happening?
Emma
Hi Emma, we would need to see the data. Can you create a Service Request for this issue and also attach some example data. We will take a look at it and get back to you.
Martyn
This was an issue in the AGS file where the Location ID had trailing spaces just for the tables that wouldn't import.
Answer Verified By: Emma Kirk
