Altering the Config Pack for Projects
We had Holebase SI for a bit before acquiring the Template Studio so there was a period where we were creating logs using the 'BS - British Standard' config pack.
Having created our own config pack for projects I can't see a way to edit the config pack for the existing projects to use our own config pack. When you 'edit' the project in the home screen although you can navigate to the tab where you would normally select the Config Pack and see the current selection there doesn't seem to be a way to actually change this (drop down menu is there but not selectable).
Anyone else worked this out?
