Will an existing installation of HOLEBASE SI be affected if I upgrade SQL 2014 from SP2 to SP3?
Not an experienced user/administrator of this software but the customer I am working for requires SQL to be updated to meet the required compliance level for CE+
For info this is currently running HoleBASE SI 1.28.0.9  - probably also well out of date...
Ideally, if anyone has migrated to a later version of SQL as well, can you share a document/rough steps to assist as they'll need to do this sooner rather than later. This service pack is a plaster on a gaping wound in terms of security - it goes EOL next year.
