OpenGround - How to Manage Grid within an existing project Location Details?
I can't edit or change the grid columns within an existing project? How can I reactivate a column that has been deselected?
Hi Devin,
Thanks for asking about this. It could be 2 things.
1. The field could have been removed from the grid. Go to System>Configuration Packs>Select the pack>Manage Model>Select the table>Select Manage Grids. Then check that the field you want is in the window on the right. If its not, move it over and save changes.
2. The field are been marked as inactive. Go to System>Configuration Packs>Select the pack>Manage Model>Select the table>Edit>Select the field>Edit, then tick the option for "Active".
I hope this helps.
Martyn
Answer Verified By: Devin Roth
No problem, happy to help.
I'm revisiting this question years later - Is it possible to toggle columns per project?
The "Edit" button in Manage Model is grayed out if you try to edit within a project.
