Is it possible to separate GINT and OpenGround Forums? Or at least have tags to tell posts apart?
EDIT: Since there is significant overlap in the features of each program, text searches are very likely to provide results for the wrong program. Even if Bentley's ultimate goal is to somehow merge these softwares, it muddies the water for current and legacy users.
Great idea Devin,OpenGround Cloud is a separate product to gINT so it makes sense to have dedicated groups.Clearly gINT users dont wanna see OGC stuff and OGC users dont wanna see gINT stuff.
This would be very helpful. If I am searching for OpenGround posts, I would like to filter out the gINT posts. Since many of the gINT posts do not include tags, I have not found a way to do this yet.
Hi both
On the Communities home screen, select from the: Go to a topic or product community drop down list, select: Keynetix , then Select Wiki, on the left you will see a menu, which includes OpenGround Cloud and Keynetix, if you expand these, they will contain only these products. Hope that helps
Hi Mel,
That does help for wiki articles. (What is the difference going forward with Keynetix and OpenGround topics, are they interchangable?)
However, it does not really help with posts on the user forums. Although a poster can add tags if they want, there is no way to see tags in the forum or filter by tags. Also, there was no reason for GINT users to tag there posts here until recently.
Keynetix was the company that Bentley acquired to gain the product now know as OpenGround Cloud.I was referring to gINT and OpenGround. They are two distinctly different applications.
