I am working on a Texas project and the Texas typically uses WINCORE software for their boring logs instead of gINT or OpenGround. I have a substantial number of borings I would like to import into OpenGround, but as far as I know, WINCORE only exports .clg and .txt files. I haven't found an efficient way to get this data into OpenGround using those file types. Does anyone know of a way to get WINCORE data into OpenGround (other than entry by hand), maybe by way of gINT or .csv?
Allison,
Dataforensics has setup an export from OpenGround to Wincore but we haven't done anything with an import from WinCore. It would be easy enough to do though - that is a pretty simple file format.
-Scott
Thanks Scott. If this comes up on another project I will make sure to get in touch with you.
