I have imported a DXF file which has uploaded but is not displayed. The DXF originated from Golden Software Surfer and exported as DXF. Coordinates system used is the same for both program - OSGB 1936.
The file is noted as 'include on Map' within the 'Manage Data Sets'.
However, when checking 'styles;' there are no points/ lines/areas noted.
Can you help?
Hi Marion,
Thanks for asking about this. Can you try using the EXPLODE command in Civils on the drawing, then resave it and try loading in to HoleBASE again. This may help.
Martyn
Hi Martyn,
This worked :)
